[GRASS-user] Re: i.rgb.his/i.his.rgb not working properly
Wed Sep 30 17:43:21 EDT 2009
Georg Kaspar wrote:
> Georg Kaspar wrote:
>   > i converted the results back to rgb and it works. pansharpening was also
> > possible using channel 8.
> > unfortunately - it still doesn't work using quickbird data
> It work's, though i had to rescale all channels to 8bit using r.mapcalc.
> Is it possible that 16bit are not supported by i.rgb.his/i.his.rgb in
> general?
AFAICT, i.rgb.his requires that the data is 0-255.
