[GRASS-user] Error in GRASS6.4 while creating image group
Nikos Dumakis nikosdu1980 at gmail.com
Wed Apr 14 17:32:21 EDT 2010
Does anyone reports the same? because that happened with Win32 and I'm using
a snapshot from 10/4/2010 in Ubuntu9.10.
It happens the same in i.cluster and in all the others menus that required
groups...
On Wed, Apr 14, 2010 at 9:11 PM, Markus Neteler <neteler at osgeo.org> wrote:
>  On Wed, Apr 14, 2010 at 7:05 PM, Nikos Dumakis <nikosdu1980 at gmail.com>
> wrote:
> > Hi
> > I'm using GRASS6.4.svn from latest week snapshot in Ubuntu and I was
> testing
> > a few functions while I got an error when creating a image group with
> > NorthCarolina Dataset.
> > I did:
> > i.group group=gr04 subgroup=sub
> > input=lsat7_2000_10 at landsat,lsat7_2000_20 at landsat,lsat7_2000_30 at landsat
> ,lsat7_2000_40 at landsat,lsat7_2000_50 at landsat,lsat7_2000_70 at landsat
> > And I got:
> > Adding raster map <lsat7_2000_10 at landsat> to group
> > Adding raster map <lsat7_2000_20 at landsat> to group
> > Adding raster map <lsat7_2000_30 at landsat> to group
> > Adding raster map <lsat7_2000_40 at landsat> to group
> > Adding raster map <lsat7_2000_50 at landsat> to group
> > Adding raster map <lsat7_2000_70 at landsat> to group
> > Adding raster map <lsat7_2000_10 at landsat> to subgroup
> > Adding raster map <lsat7_2000_20 at landsat> to subgroup
> > Adding raster map <lsat7_2000_30 at landsat> to subgroup
> > Adding raster map <lsat7_2000_40 at landsat> to subgroup
> > Adding raster map <lsat7_2000_50 at landsat> to subgroup
> > Adding raster map <lsat7_2000_70 at landsat> to subgroup
> > Then when I open i.cluster GUI I selected gr04 group and, sub doesn't
> appear
> > in subgroup. It only appears "Not a selectable element". If I leave it
> blank
> > it doesn't run (sub group is a required option). But, if I write  "sub"
> it
> > works...
> > Is this suppose to happen?
> I would say no. It reminds me of
> http://trac.osgeo.org/grass/ticket/780
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100414/7107666e/attachment.html
