[GRASS-user] v.db.connect -p
Markus Metz markus.metz.giswork at googlemail.com
Tue Aug 3 06:21:03 EDT 2010
Markus Neteler wrote:
> Patricio Toledo wrote:
>> Dear GRASS Developers
>> This is a petition:
>> Is it possible to add a option to v.db.connect (like g.region -p) so
>> the output will be somelike:
>>    $ v.db.connect -p map=test layer=2
>>    driver=dbf
>>    database=/the/database
>>    table=thetable
>>    column=thecolumn
>>    layer=2
>> i know -p actually does something very similar but this -p output is very useful
>> in g.region, so one can do inside a shell-script:
>>    $eval `v.db.connect -p map=test`
>> to recover database connection parameters.
> There is -g
>  -g   Print all map connection parameters and exit in shell script style
>        Format: layer[/layer name] table key database driver
> but it doesn't work as advertised (it is not shell script style!):
> v.db.connect -g map=streets_wake
> 1 streets_wake cat /home/neteler/grassdata/nc_spm_08/PERMANENT/dbf/ dbf
> even with fs="=" it makes a mess:
> v.db.connect -g map=streets_wake  fs="="
> 1=streets_wake=cat=/home/neteler/grassdata/nc_spm_08/PERMANENT/dbf/=dbf
> Essentially, the line breaks are missing.
> Should be a simple thing to fix.
try trunk r42980
Markus M
