[GRASS-user] Reprojection command
Giacomo Piva piva at meeo.it
Thu Aug 5 04:43:31 EDT 2010
Hi Hamish,
Thank you for reply.
This command assume that I set up the computational region, I have many
problems with setting region and I recive many errors like
ERROR: region for current mapset is not set
        run "g.region"
How can I set a region from scratch?
I'm using this sequence of functions:
g.region -p
r.in.gdal -o -e --overwrite input=<input raster> output=<output>
location="$LOCATION"
And the output is:
projection: 0 (x,y)
zone:       0
north:      2030
south:      0
west:       0
east:       1354
nsres:      1
ewres:      1
rows:       2030
cols:       1354
cells:      2748620
        run "g.region"
Thank you
On 08/05/2010 10:34 AM, Hamish wrote:
> Giacomo wrote:
>> Which is the command to use for reproject an image?
>> I usually use gdalwarp to reproject the image BEFORE grass
>> command, but now I want to reproject an image between two
>> grass command.
> r.proj. You pull a map in from another mapset into the current
> computational region (see the help page).
> Hamish
Giacomo
