[GRASS-user] module v.in.e00
ambrish dhaka ambijat at hotmail.com
Fri Aug 6 17:30:30 EDT 2010
I have a problem with this import command. Whenever I try to import an E00 file it shows that I have not installed. I checked it again by running the OSGEO4W installation patch and there I crossed checked that avce00 library is also installed, but this problem simply does not go away and it keeps recurring as folows.
v.in.e00 "file=C:/Documents and Settings/ishan/My Documents/Downloads/25192/hypoint.e00" type=point vect=hypoint
which: e00conv: unknown command
'e00conv' program not found, install it first
http://avce00.maptools.org
Finished with error
Help is needed!
Ambrish Dhaka
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100806/345f0480/attachment.html
