[GRASS-user] GeoTIFF output question (number of bytes divisible by 8?)
stephen sefick ssefick at gmail.com
Mon Aug 9 10:18:22 EDT 2010
If anyone is interested I had to export the files in AAIGrid format
with a no data value =0 (elevations well above sea level) and then use
gdal_translate to turn this into a geotiff.
#GRASS out
r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms
nodata=0 format=AAIGrid
#translate to goetiff
gdal_translate -of GTIFF fcms fcms_g.tiff
then tauDEM command line functions seem to work fine.
If I am missing something please inform me.
Again, thanks for all of the help!
Stephen Sefick
On Mon, Aug 9, 2010 at 8:06 AM, stephen sefick <ssefick at gmail.com> wrote:
> Thank you- I will figure all of this out one day...  I thank you all
> for your kind support.
> kindest regards,
> Stephen Sefick
> On Mon, Aug 9, 2010 at 8:05 AM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> stephen sefick wrote:
>>> I am using
>>> r.out.tiff -t input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>> Use
>> r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>>> for input into the tauDEM pitremove function (compiled from source)
>> BTW, with r.out.tiff you get a standard tiff image with color values
>> (0 - 255, 3 bands for RGB), not elevation values.
>> Markus M
> Stephen Sefick
> ____________________________________
> | Auburn University                                   |
> | Department of Biological Sciences           |
> | 331 Funchess Hall                                  |
> | Auburn, Alabama                                   |
> | 36849                                                    |
> |___________________________________|
> | sas0025 at auburn.edu                             |
> | http://www.auburn.edu/~sas0025             |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
>                                 -K. Mullis
Stephen Sefick
| Auburn University                                   |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
                                -K. Mullis
