[GRASS-user] GeoTIFF output question (number of bytes divisible by 8?)
stephen sefick ssefick at gmail.com
Mon Aug 9 10:42:52 EDT 2010
no data not defined is the error message with a straight write out in
geotiff when fed into tauDEM.
I am at a loss for why this would not work.
On Mon, Aug 9, 2010 at 9:36 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> stephen sefick wrote:
>> If anyone is interested I had to export the files in AAIGrid format
> Why did export directly to GeoTIFF not work?
>> with a no data value =0 (elevations well above sea level) and then use
>> gdal_translate to turn this into a geotiff.
>> #GRASS out
>> r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms
>> nodata=0 format=AAIGrid
>> #translate to goetiff
>> gdal_translate -of GTIFF fcms fcms_g.tiff
>> then tauDEM command line functions seem to work fine.
>> If I am missing something please inform me.
>> Again, thanks for all of the help!
>> Stephen Sefick
>> On Mon, Aug 9, 2010 at 8:06 AM, stephen sefick <ssefick at gmail.com> wrote:
>>> Thank you- I will figure all of this out one day...  I thank you all
>>> for your kind support.
>>> kindest regards,
>>> Stephen Sefick
>>> On Mon, Aug 9, 2010 at 8:05 AM, Markus Metz
>>>>> I am using
>>>>> r.out.tiff -t input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>>>> Use
>>>> r.out.gdal input=fcms at PERMANENT output=/home/ssefick/Desktop/fcms.tiff
>>>>> for input into the tauDEM pitremove function (compiled from source)
>>>> BTW, with r.out.tiff you get a standard tiff image with color values
>>>> (0 - 255, 3 bands for RGB), not elevation values.
>>>> Markus M
>>> Stephen Sefick
>>> ____________________________________
>>> | Auburn University                                   |
>>> | Department of Biological Sciences           |
>>> | 331 Funchess Hall                                  |
>>> | Auburn, Alabama                                   |
>>> | 36849                                                    |
>>> |___________________________________|
>>> | sas0025 at auburn.edu                             |
>>> | http://www.auburn.edu/~sas0025             |
>>> Let's not spend our time and resources thinking about things that are
>>> so little or so large that all they really do for us is puff us up and
>>> make us feel like gods.  We are mammals, and have not exhausted the
>>> annoying little problems of being mammals.
>>>                                 -K. Mullis
>> Stephen Sefick
>> | Auburn University                                   |
>> | 331 Funchess Hall                                  |
>> | Auburn, Alabama                                   |
>> | 36849                                                    |
>>                                 -K. Mullis
Stephen Sefick
| Auburn University                                   |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
                                -K. Mullis
