[GRASS-user] GADM & Polygon files in general
Markus Metz markus.metz.giswork at googlemail.com
Mon Aug 9 15:10:04 EDT 2010
Thomas, Timothy (IFPRI) wrote:
> It leads naturally into a few questions.
> 2)  Since I have over 1,000 hours of computer time in converting using
> GRASS 6.4 on Linux with 8GB RAM, what in the world happened in GRASS 7
> that it can now do it in only 4 hours???
First, I imported the whole thing at once, not each country
separately. Second, some under-the-hood modifications in GRASS 7 of
the cleaning procedures result in reduced memory consumption and
faster import.
> 3)  Would someone be able to tell me whether the commands I have been
> using are the most efficient and correct, or whether that was the cause
> of the slow speed in the first place?
> For importing a shapefile, I used a command like:
>    v.in.ogr dsn=gadm1 layer=usa_gadm1 out=usa_gadm1 -o
Why the -o flag? GADM shapefiles come with a *.prj file, i.e.
projection information is available and should not be ignored.
> And if they do not have great boundaries, a command like
>    v.in.ogr dsn=gadm1 layer=usa_gadm1 out=usa_gadm1 snap=0.00002 -o
Looks ok, but gadm is AFAICT clean, snapping boundaries is not necessary.
> To combine 2 countries, I would use something like
>    v.patch -e in=usa_gadm1,can_gadm1 out=namer_gadm1
Watch out for category values when patching. I would prefer to import
the whole thing at once, or the county you are interested in.
> And to repair the boundaries, something like
>    v.clean namer_gadm1 out=namer_cln_gadm1 tool=snap,break,rmdupl
> thresh=0.00002
Looks ok, but for gadm this should not be necessary.
Markus M
