[GRASS-user] GRASS compiled from source: child_exception
LeeDaniel Lee.Daniel.1986 at gmail.com
Wed Aug 11 10:16:59 EDT 2010
Hi all,
I've got another problem again. Since I had so much trouble with getting
g.extension to work and never managed to get the add-on I desperately need
to compile (r.area), I'm trying it now with GRASS compiled from source. I
tried GRASS 7 and now I've tried GRASS 6.5, both with the same results.
I'm running OpenSUSE 11.3, 32 bit. Since the problem's been the same with 7
and 6.5, I'll show the more recent terminal outputs from 6.5.
Installed the latest 6.5-svn code from
http://grass.itc.it/grass65/binary/linux/snapshot/. Here's how I did it:
- Downloaded grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010-install.sh
and grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010.tar.gz into the same
directory
- Ran
sudo sh grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010-install.sh
GRASS installed itself with the following output:
GRASS GIS 6.5.svn-x86_64-unknown-linux-gnu-07_08_2010 binary package
installation tool
Using gunzip decompressor...
The package grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010.tar.gz seems
to be o.k.
 Proceeding...
Checking and creating installation directory...
Installing GRASS binaries into
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010
Uncompressing the package and extracting to target directory...
Creating start script:
/usr/local/bin/grass65 ->
/usr/local/bin/grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010
Creating the locks directory for monitors...
Creating datum transformation gridshift files...
Generating display font configuration file...
grass-6.5.svn-x86_64-unknown-linux-gnu-07_08_2010-install.sh: line 344:
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/bin/g.mkfontcap:
cannot execute binary file
Installation finished. Start GRASS
6.5.svn-x86_64-unknown-linux-gnu-07_08_2010 with
Welcome to GRASS GIS. Enjoy this open source GRASS GIS!
So far so good, although the inability to execute g.mkfontcap did worry me.
Then I started GRASS with the command grass65 and got the following output:
Lee at pc19392:~/Downloads> grass65
WELCOME TO GRASS              Version 6.5.svn         2010
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      are extremely useful:
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
      http://www.grass-gis.org
      http://grass.osgeo.org
Hit RETURN to continue
Starting GRASS ...
  File
"/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/wxpython/gis_set.py",
line 37, in <module>
    import gui_modules.goutput
  File
"/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/wxpython/gui_modules/goutput.py",
    import preferences
  File
"/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/wxpython/gui_modules/preferences.py",
line 911, in <module>
    globalSettings = Settings()
  File
line 585, in __init__
    self.ReadSettingsFile()
  File
line 650, in ReadSettingsFile
    gisenv = grass.gisenv()
  File
"/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/python/grass/script/core.py",
line 505, in gisenv
    s = read_command("g.gisenv", flags='n')
  File
line 216, in read_command
    ps = pipe_command(*args, **kwargs)
  File
line 193, in pipe_command
    return start_command(*args, **kwargs)
  File
line 155, in start_command
    return Popen(args, **popts)
  File
line 53, in __init__
    startupinfo, creationflags)
  File "/usr/lib/python2.6/subprocess.py", line 633, in __init__
    errread, errwrite)
  File "/usr/lib/python2.6/subprocess.py", line 1139, in _execute_child
    raise child_exception
OSError: [Errno 8] Exec format error
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/Init.sh:
line 647:
/usr/local/grass6.5.svn-x86_64-unknown-linux-gnu-07_08_2010/etc/set_data:
Now matter what I do, this same problem keeps on coming up.I don't know what
to do. I've got wxpython installed (for GRASS 7 it complained about now
having that - I reinstalled my system completely since I've last written and
hadn't installed it, but not it's on there with the development files so it
should be okay). Any ideas? I get the same error message with GRASS 7.
Any help would be greatly appreciated! Thanks a bunch in advance,
Daniel
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-compiled-from-source-child-exception-tp5412414p5412414.html
Sent from the Grass - Users mailing list archive at Nabble.com.
