[GRASS-user] AdvancedViewshedAnalysis
Rebecca Rennell lostbex at hotmail.com
Fri Aug 13 06:38:26 EDT 2010
Hi GRASS-Users
Apologies for cross-posting.
My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
command 'gem6' is not recognised
command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
ERROR:  Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
I have an older version of GRASS (GRASS 6.3.0). From here the command
'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:
ERROR: Compilation failed for these module(s):
/private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
/private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
Run 'make' manually in each module's directory for details.
make: *** [default] Error 1
I've now run make in both modules (I think), but I still get the same error message.  I also don't understand why the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help gratefully received!
Thanks
Becky
grass-user at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100813/986983c4/attachment.html
