[GRASS-user] AdvancedViewshedAnalysis
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Fri Aug 13 10:45:05 EDT 2010
Hi Becky,
if you want to have it super easy, download and install
gvSIG OADE 2010:
  http://www.oadigital.net/software/gvsigoade
When you run the installer, make sure to tick all available
extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
Full instructions are here:
  ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
A quickstart guide for gvSIG is also available:
  ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
... but surely, someone at your department is already using gvSIG?
You can then run a large number of GRASS modules directly via
the SEXTANTE graphical user interface.
r.cva and r.promincence are already included.
Best,
Ben
On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
> Hi GRASS-Users
> Apologies for cross-posting.
> My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
> command 'gem6' is not recognised
> command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
> ERROR:  Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
> I have an older version of GRASS (GRASS 6.3.0). From here the command
> 'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:
> ERROR: Compilation failed for these module(s):
> /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
> /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
> Run 'make' manually in each module's directory for details.
> make: *** [default] Error 1
> I've now run make in both modules (I think), but I still get the same error message.  I also don't understand why the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help gratefully received!
> Thanks
> Becky
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
