[GRASS-user] Re: i.atcorr returns all NULL values
zackparisa zacharyparisa at gmail.com
Fri Aug 13 23:19:14 EDT 2010
I am getting the same error when working with AVNIR data. Bands 1 and 4 go
through great--however when the sensor condition codes are used for bands 2
and 3 (82 and 83 respectively) the outuput is full of NULL values.
I ran a similar test as Brian-- used the sensor condition codes from bands 1
and 4, and the output in those cases were fine.
I'm using Grass 6.5 on Ubuntu 10.4 64bit
Example code:
##THIS WORKS##
i.atcorr -o iimg=ALAV2A068212970-O1B2G_U_04rectified at PERMANENT iscl=0,255
ialt=dem_patch at PERMANENT
icnd=/home/hannibal/Projects/LandM/spring_iatcor_4.txt
oimg=ALAV2A068212970-O1B2G_U_04rectified_at oscl=0,255 --overwrite
WHERE the icnd file =
11
05 06 16.900 -89.967 31.318
2
1
9.65
-0.100
-1000
84
FROM r.info on result:  Range of data:    min = 0  max = 255
##THIS DOESN'T WORK##
i.atcorr -o iimg=ALAV2A068212970-O1B2G_U_02rectified at PERMANENT iscl=0,255
icnd=/home/hannibal/Projects/LandM/spring_iatcor_2.txt
oimg=ALAV2A068212970-O1B2G_U_02rectified_at oscl=0,255 --overwrite --verbose
11
2
1
9.65
-0.100
-1000
82
FROM r.info on result: Range of data:    min = NULL  max = NULL
Any ideas on this would be very much appreciated...I just can't figure out
where the issue is.
Thanks,
Zack
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-returns-all-NULL-values-tp4975543p5422319.html
Sent from the Grass - Users mailing list archive at Nabble.com.
