[GRASS-user] v.dissolve - is this a bug?
Markus Neteler neteler at osgeo.org
Mon Aug 16 04:08:26 EDT 2010
On Sat, Aug 14, 2010 at 10:16 AM, Richard Chirgwin
<rchirgwin at ozemail.com.au> wrote:
> Hi,
> In running v.dissolve within a script, I am getting an intermittent failure:
> ERROR: key column must be integer or string
> Here's the script spot that fails (but only sometimes)
> v.db.addtable MAP
> v.db.addcol MAP columns="Dissolve int"
At this point, please run
v.info -c MAP
and report here.
> v.db.update MAP column=Dissolve value=1
> v.dissolve MAP output=DISSOLVE column=Dissolve
> The killer is that it isn't reliable - sometimes it works, sometimes it
> fails, and I can't tell why!
Always on the same machine, the same binary and the same map?
Markus
