[GRASS-user] Flow Direction Map Question (r.stream.extract)
stephen sefick ssefick at gmail.com
Wed Aug 18 18:47:57 EDT 2010
Hamish,
It is D8.  I am not entirely sure what you mean.
On Wed, Aug 18, 2010 at 5:38 PM, Hamish <hamish_b at yahoo.com> wrote:
>> stephen sefick pisze:
>> I am trying to use a direction map from taudem with the
>> r.stream modules.  I think the problem may be that -8 to 8
>> is the range of value in the r.stream extract version and 1-8
>> in the taudem version.
>> I can generate one with r.stream extract with the flow
>> accumulation and the filled DEM from taudem.  The raster
>> stream network are very similar, but not totally the same.
> if results are categorical (D8) I'd suggest to use r.reclass to
> sync them.
> Hamish
Stephen Sefick
____________________________________
| Auburn University                                   |
| Department of Biological Sciences           |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
|___________________________________|
| sas0025 at auburn.edu                             |
| http://www.auburn.edu/~sas0025             |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
                                -K. Mullis
