[GRASS-user] Python scripts: 'command not found'
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Aug 19 09:42:12 EDT 2010
On Thursday 19 of August 2010 15:13:37 Hanlie Pretorius wrote:
> I'm working in GRASS 6.4RC6 on Ubuntu 10.04 and I'm trying to learn
> how to script GRASS using Python.
> I have taken the example at
> http://grass.osgeo.org/programming6/pythonlib.html that checks if a
> vector is 3D and saved it to my home folder. When I try to run it
> though, GRASS can't find the file:
> GRASS 6.4.0RC6 (sa_wgs84):~ > ls *.py
> check_3d.py  proxy.py
> GRASS 6.4.0RC6 (sa_wgs84):~ > check_3d.py
> check_3d.py: command not found
Try "python check_3d.py" or copy the script under the "scripts" directory in
your local grass installation (somethin' lke
"/usr/local/grass-6.4.0svn/scripts").
> I also tried placing the script in the GRASS scripts folder using the
> name 'v.check3d' and got the following errors:
A, ok! You already did that.
> GRASS 6.4.0RC6 (sa_wgs84):~ > v.check3d
> bash: /usr/lib/grass64/scripts/v.check3d: Permission denied
> GRASS 6.4.0RC6 (sa_wgs84):~ > sudo v.check3d
> [sudo] password for hanlie:
> sudo: v.check3d: command not found
Better not to use sudo (as a general advice). The script needs to be made
executable for your user-name, i.e.:
sudo chown hanlie:hanlie  v.check3d
Hope this helps, Nikos
