[GRASS-user] speeding up v.overlay
Markus Metz markus.metz.giswork at googlemail.com
Tue Aug 24 05:22:21 EDT 2010
Stuart Gralton wrote:
> Hello Everyone,
> I am trying to use v.overlay to clip contour lines for a specific area. The
> contour lines were imported into GRASS from a shapefile which is about 33Mb.
> The query was as follows:
> v.overlay ainput=contour atype=line binput=boundingbox output=contour_clip
> operator=and
> The operation took 16 hours to complete, which seems excessive. Is there
> anything that I can do to speed things up?
> I am aware of v.split, v.select, v.clean as suggestions from other posts as
> ways of increasing performance. Unfortunately none of these helped me very
> much:
>     v.split seems to drop the attribute table (but it has amazing effects on
> performance).
v.spllt does copy all attribute tables. Can you post the output of
v.db.connect -p or v.db.connect -g for the original vector and the
output of v.split?
Markus M
>     v.select helps a little, but due to the nature of the data, not many
> features are removed.
>     v.clean did not have any effect. The data is from the government, and is
> already of high quality.
> Is there anything that I am missing? Or is there any way to preserve the
> attribute table when using v.split?
> Thanks in advance,
> Stuart
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
