[GRASS-user] speeding up v.overlay
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Tue Aug 24 09:14:56 EDT 2010
Stuart Gralton wrote:
> v.db.connect -p cont
> Vector map <cont at PERMANENT> is connected by:
> layer <1> table <cont> in database
> </home/stuart/grassdata/aawt_mga55/PERMANENT/dbf/> through driver <dbf>
> with key <cat>
Stuart a general recommendation (in case you are not aware of it): better to
work with data in user-Mapsets and not in PERMANENT.
That is: create a new user-mapset, switch to it and g.copy the "to-be-
processed" material. This way ensures keeping intact the original imported
maps -- mistakes can be very time expensive.
Regards, Nikos
