[GRASS-user] Raster: r.report vs r.info
Andrew Lewin andrew.lewin at sympatico.ca
Fri Aug 27 12:29:59 EDT 2010
Hi Mark,
That worked! Thanks! It's always the simplest things.  I'm new to GRASS but not to GIS.  I just need to gain some experience tinkering around with the software.  This list helps with the small things.
Thanks Again!
Cheers,
Andrew
Andrew Lewin
Founder of Oceans and Coasts Blog
President
Coastal/Marine Spatial Ecologist
Spatial-Conserve Incorporated
Associate
C-FOAM (Canadian Fisheries, Oceans and Aquaculture Management Group)
Telfer School of Management, University of Ottawa
On 2010-08-27, at 12:19 PM, Mark Seibel wrote:
> Maybe your region computation area needs set to the extent of the
> data?  It looks like it is only one cell with south and west being 0,
> and north and east being 1.
> Mark
> On Fri, Aug 27, 2010 at 12:11 PM, Andrew Lewin
> <andrew.lewin at sympatico.ca> wrote:
>> Hi Everyone,
>> I am having trouble with creating categories for a raster map (floating
>> point).
>> I used r.reclass to create a category for my raster (temperature values;
>> floating point).  I thought I successfully added categories but when I ran
>> r.report there are no categories; however, when I run r.info for the raster
>> it shows that I have two categories.
>> Can anyone give me a hand with this problem?  The results of the r.report
>> and r.info are below:
>> r.report:
>> GRASS 6.4.0RC6 (MacrophytesGIS):~/grass/MacrophytesGIS/PERMANENT > r.report
>> mynatemp4reclass
>>  100%
>> |                         RASTER MAP CATEGORY REPORT
>> |LOCATION: MacrophytesGIS                             Fri Aug 27 12:00:05
>> 2010|
>> |          north: 1N    east: 1E
>> |REGION    south:  0    west:  0
>> |          res:    1    res:   1
>> |MASK:none
>> |MAP: Reclass of mynatemp4 in PERMANENT (mynatemp4reclass in PERMANENT)
>> |                            Category Information
>> |#|description
>> |*|no data
>> r.info:
>> GRASS 6.4.0RC6 (MacrophytesGIS):~/grass/MacrophytesGIS/PERMANENT > r.info
>> mynatemp4reclass
>>  | Layer:    mynatemp4reclass               Date: Thu Aug 26 15:25:18 2010
>>  | Mapset:   PERMANENT                      Login of Creator: andrewlewin
>>  | Location: MacrophytesGIS
>>  | DataBase: /Users/andrewlewin/grass
>>  | Title:    Reclass of mynatemp4 in PERMANENT ( mynatemp4reclass )
>>  | Timestamp: none
>>  |   Type of Map:  reclass              Number of Categories: 2
>>  |   Data Type:    CELL
>>  |   Rows:         251
>>  |   Columns:      434
>>  |   Total Cells:  108934
>>  |        Projection: Latitude-Longitude
>>  |            N: 82:39:08.872N    S: 14:28:55.128N   Res: 0:16:17.744
>>  |            E: 52:28:47.899422W    W: 170:21:08.795422W   Res: 0:16:17.744
>>  |   Range of data:    min = 1  max = 2
>>  |   Data Source:
>>  |    Reclassified map based on:
>>  |      Map [mynatemp4] in mapset [PERMANENT]
>>  |   Data Description:
>>  |    generated by r.reclass
>>  |   Reclassification of [mynatemp4] in mapset [PERMANENT]
>>  |         Category        Original categories
>>  |          1              -20--1
>>  |          2              0-29
>> Cheers,
>> Andrew
>> Andrew Lewin
>> President
>> Associate
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100827/0007bae6/attachment.html
