[GRASS-user] Best format for exporting raster data
Sylvain Maillard sylvain.maillard at gmail.com
Tue Aug 31 10:56:00 EDT 2010
Perhaps can you add an extra loop in your scripts for processing your data:
1 - extract the tarball
2 - import the raster in R
3 - and then delete the temporary uncompressed mapset.
it will take a little bit more space but just for one mapset at a time, and
I don't thing the process will be much slower than to access the files
directly into the compressed tarball ...
you can also buy more hard drive :D
if you make some benchmark test between different solution I will be
interreted in the results, I'm also working on a huge amound of raster data
within GRASS and R ...
regards,
Sylvain Maillard
Doctorant en Sciences de l'Environnement
Laboratoire Chimie Provence - UMR 6264 / Université de Provence
la Tour du Valat - Centre de recherche pour la conservation des zones
humides méditerranéennes
Le Sambuc
13200 Arles
France
tél:04.90.97.29.79
fax:04.90.97.20.19
www.tourduvalat.org
2010/8/31 Rainer M Krug <r.m.krug at gmail.com>
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 31/08/10 16:38, Markus Neteler wrote:
> > On Tue, Aug 31, 2010 at 4:13 PM, Rainer M Krug <r.m.krug at gmail.com>
> wrote:
> >>> I would leave it in GRASS and use the R-GRASS interface and/or the
> >>> GDAL-GRASS plugin. See the Wiki for details.
> >> I am doing that already - but I don't think that works when I have the
> >> grass mapset compressed as a .tar.gz?
> > I found "archivemount" which apparently lets you
> > mount a possibly compressed tarball as a filesystem:
> > http://en.wikipedia.org/wiki/Archivemount
> > http://www.linux.com/archive/feature/132196
> Sounds interesting - I'll look into that.
> Thanks,
> Rainer
> > Cheers
> > Markus
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Natural Sciences Building
> Office Suite 2039
> Stellenbosch University
> Main Campus, Merriman Avenue
> Stellenbosch
> South Africa
> Tel:        +33 - (0)9 53 10 27 44
> Cell:       +27 - (0)8 39 47 90 42
> Fax (SA):   +27 - (0)8 65 16 27 82
> Fax (D) :   +49 - (0)3 21 21 25 22 44
> Fax (FR):   +33 - (0)9 58 10 27 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAkx9Fo0ACgkQoYgNqgF2egot0gCaA4EJiyfYkRYjYXeJpKSBLaGT
> V5QAoITs1O5Npb81z0UvSYtY2tTtc7cy
> =rcm6
> -----END PGP SIGNATURE-----
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100831/f695cf01/attachment.html
