[GRASS-user] problem with v.proj building topology
Margherita Di Leo diregola at gmail.com
Mon Dec 6 06:16:59 EST 2010
Hi Markus,
Thanks for answering. I solved using:
ogr2ogr -s_srs EPSG:23032 -t_srs EPSG:32632 repr_suolo_paes.shp
suolo_paes_ext.shp
and imported the reprojected map with v.in.ogr. All polygons are reprojected
now.
But I noticed that using v.proj the map was reprojected with an important
error .I have another map of the same area, when I try to overlay them they
are in two different places, very far apart. But when I overlay the map
reprojected with ogr, everythings looks OK.
Couldn't it be a bug of v.proj? Has anyone had a similar problem using
v.proj?
Thank you
Margherita
2010/12/5 Markus Neteler <neteler at osgeo.org>
> Hi Margherita,
> On Sat, Dec 4, 2010 at 8:18 PM, Margherita Di Leo <diregola at gmail.com>
> wrote:
> > Hi List,
> > I have a problem using v.proj. In in the destination location the vector
> map
> > is incomplete, it seems that the topology is not completely built. In
> > particular, there are missing polygons. The command line:
> > v.proj input=suolo_paes_ext location=UTM_32_ED50 mapset=mimmo
> > output=suolo_paes_ext --o
> > gives the following WARNING:
> > Building topology for vector map <suolo_paes_ext>...
> > Registering primitives...
> > 5305 primitives registered
> > 26646 vertices registered
> > Building areas...
> > WARNING: Area of size = 0.0 ignored
> You are reprojecting from UTM_32_ED50 into ...?
> > I also tried to use v.build after that, without results.
> In any case, you may need to clean up the topology *before* running v.proj.
> Perhaps the original map isn't clean.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101206/3056e657/attachment.html
