[GRASS-user] Re: Where the grassdata base resides
Micha Silver Micha at arava.co.il
Thu Dec 9 06:34:03 EST 2010
Catlike wrote:
> Thank you.
> Yes, the directory name does contain white space.
> I'm using GRASS 6.4.0.
> The GRASS "login" window comes up, and I specify the database location,
> then use the Location Wizard to create a location, and click Start. A
> scripting window briefly opens, then that window and the GRASS login
> window both close and there is nothing more.
I don't know why this isn't working for you. But I might suggest a way to
get up and running without too much fuss: Use the QGIS GRASS plugin to
create your gisdatabase, location and mapset. The "New GRASS Location"
wizard is easy to follow. Then close QGIS and point GRASS to that same
gisdbase directory and all should be well.
You might find the QGIS GRASS plugin convenient to use for many other jobs
as well.
Just go to http://www.qgis.org/wiki/Download to get the latest version for
your system. The GRASS plugin is installed automatically.
Micha
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Where-the-grassdata-base-resides-tp5813667p5818672.html
Sent from the Grass - Users mailing list archive at Nabble.com.
