[GRASS-user] Can I use r.mapcalc to create "sorted" elevation raster?
Catlike cogreg at gmail.com
Sun Dec 26 05:51:28 EST 2010
Thank you for reading.
I am trying to use r.mapcalc, through QGIS, to take an elevations raster
with a wide variety of values and create a new elevations raster which only
contains those cells that have a value over a certain number (in this case,
300 meters).
Unfortunately, the QGIS graphic user interface does not show me what the
actual command I create is.
What I get when I run the command is a new raster in which every cell has
been converted to equal 300 meters!
What should I do differently?
Again, thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-I-use-r-mapcalc-to-create-sorted-elevation-raster-tp5867462p5867462.html
Sent from the Grass - Users mailing list archive at Nabble.com.
