[GRASS-user] Two General Questions
Jarek Jasiewicz
jarekj at amu.edu.pl
Fri Feb 12 13:41:11 EST 2010
Rich Shepard pisze:
> On Fri, 12 Feb 2010, Jarek Jasiewicz wrote:
>>> 1) Can GRASS work with TINs for elevation determinations? I've not
>>> seen
>>> anything about it, yet I've read that it has advantages over
>>> raster-based
>>> DEMs for some purposes and wonder if there are any plans to
>>> accommodate this
>>> data structure.
>> No
> That's what I thought, Jarek.
>> d.rast -o see d.rast
> I completely forgot about the overlay switch. Thank you.
>> I also suggest nviz and nviz documentation.
> I'm working my way through the documentation and slowly learning how to
> use nviz.
>> I also suggest you Open Source GIS a GRASS GIS approach by Marcus
>> Neteler and Helena Mitasova
> Have the second edition which I've thoroughly read.
>> nviz give you really impressive visuals with maximum resolution ppm
>> images
>> (require posterior GIMP post processing) but please! read manual first.
maximum resolution ppm will give you tiled image which must be joined
> I'll do more with this. All I did so far with the GIMP is crop the
> image.
> Then I converted it to .jpg for inclusion in the LaTeX document.
> If you have suggestions for post-processing with the GIMP, I'd like to
> learn them.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
