[GRASS-user] upgrade opensuse11.2 grass64
Otto Dassau otto.dassau at gmx.de
Tue Feb 16 05:03:21 EST 2010
Hi Joop,
On Tue, 16 Feb 2010 10:25:00 +0100
Joop Goedbloed <jlgoedbloed at hetnet.nl> wrote:
> Op 16-02-10 09:03, Otto Dassau schreef:
> Hi Otto
> The messages (so far as I'v tested) only appear when I'v doing something
> like display, digitize etc. with vector maps.
just tested with an opensuse 11.2 64bit. I opened the tcltk gui, loaded the
spearfish map "streams", started the digitizing module in the tcltk gui,
deleted a stream, closed/saved it, closed the tcltk gui and got following
message.
*** glibc detected *** gis.m: double free or corruption (out):
0x000000000103c6d0 ***
Then I tried it a second time but did not get any errors anymore. And my
message is different from the one you sent - strange. And apart from this
message, everything works normal.
> > With wxpython  gui there is no problem with tcl/tk gui grass64 is
> > looking for tcl/tk 8.4 on my system there is version 8.5
> > thats probable the problem.
the grass package for opensuse 11.2 is compiled based on the standard tcl/tk
8.5. I guess something went wrong during the update, when your grass
installtion is still looking for tcl/tk 8.4. Btw. from what opensuse did you
upgrade, because 11.1 also uses tcl/tk 8.5 AFAIK.
Regards,
 Otto
> > Hi,
> > have you installed the grass package from the Application:Geo
> > Repository? I updated those packages with a current svn snapshot from
> > 6. Feb. 2010. As far as I tested, they work fine, except the known bug
> > described here:
> > http://trac.osgeo.org/grass/ticket/928
> > You should make sure to update all packages and libraries on your
> > system are uptodate. This can be done in YAST.
> > hth
> >  Otto
> > Am Mon, 15 Feb 2010 20:20:48 -0800 (PST)
> > schrieb Hamish <hamish_b at yahoo.com>:
> >> Joop wrote:
> >>> Last day I've upgrade to OpenSuSe 11.2 and reinstall
> >>> Grass64 (6.4.0svn (2010))
> >> how did you reinstall?
> >> if building from source make sure to do "make distclean" and rebuild.
> >>> Grass64 is runnig wel but when closing the gui I get a list of
> >>> "errors!!??" like this below:
> >>> GRASS 6.4.0svn (Venlo):~ > *** glibc detected *** wish:
> >>> corrupted double-linked list: 0x081330a0
> >>> /usr/lib/libtcl8.5.so[0xb75644e6]
> >> something's broken with tcl/tk.
> >> probably a program is built for an old version of the library but now
> >> you have a new one in its place.
> >> Hamish
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
