Fwd: [GRASS-user] Apply a segmentation to derive objects
Nikos Dumakis nikosdu1980 at gmail.com
Fri Feb 26 10:21:56 EST 2010
You are absolutely right :) My mistake. SMAP is a segmentation algorithm.
But my idea was not to use SMAP as a classification but use a Segmentation
process and only then a Supervides Classification. Or if Use SMAP I'm doing
both things in this order?
Thanks Markus
Nikos
On Mon, Jan 18, 2010 at 11:22 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jan 18, 2010 at 6:30 PM, Nikos Dumakis <nikosdu1980 at gmail.com>
> wrote:
> > Greetings all
> > I've been following GRASS-user discussion related with
> pos-classigfication,
> > classification, aggregation and so on. But, while I was readingh those
> > emails I figured that I will need to perform, before classification, an
> > image segmentation to derive objects.
> You don't need to perform a segmentation before doing classification but
> i.smap is doing it in a combined way.
> > Can anyone give me a clue abvout that because in GRASS book, I only
> founded
> > Image segmentation related with processing large quantities of vectorial
> > data (DEM's).
> (DEMs are raster data)
> What you need to do is to prepare the statistics with i.gensigset. See
> "radiometric & geometric  supervised" in
> http://grass.osgeo.org/wiki/Image_classification
> (The book is explaining that as well)
> Hope this helps,
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100226/acc97130/attachment.html
