[GRASS-user] ps.map Advice
Nick Cahill ndcahill at wisc.edu
Mon Jan 4 14:35:58 EST 2010
I use ps.map only to export vectors to postscript. I then use v.in.region to create a box to show the region for any raster data (which is what takes up all the room in your postscript output), then use r.out.tif or whatever to dump the raster as a separate tif file; then merge the two in Adobe Illustrator (which is what I use for final map composition). An extra step, but gives lots of control.
Nick Cahill
On Jan 4, 2010, at 1:26 PM, Rich Shepard wrote:
>  The output files from ps.map are huge: the .ps is about 665M and the .pdf
> is 9.9M. Way too large!
>  The DEM is at 10m cell size. 'g.region -p' produces:
> projection: 99 (Lambert Conformal Conic)
> zone:       0
> datum:      nad83
> ellipsoid:  grs80
> north:      1334419.15160578
> south:      1279151.24118496
> west:       769192.92822895
> east:       819255.92362222
> nsres:      7.49700358
> ewres:      3.37898187
> rows:       7372
> cols:       14816
> cells:      109223552
>  This has fewer cells than the source raster DEM covering a larger region
> (18,724 rows, 24,657 columns, 461,677,668 cells).
>  Should I change the nsres and ewres to 10.0? Should I change the number of
> rows and columns? Your advice is needed to produce high quality output at
> reasonable .pdf size.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
