[GRASS-user] ps.map: labels
Hamish hamish_b at yahoo.com
Tue Jan 5 09:23:07 EST 2010
Rich:
> The file proj_pnt.lab contains the v.label command specifying map,
> attribute column, and x/y offsets.
as in the shell command to make the label file? ps.map expects the processed
file, not the command to the program that creates it. (among other things
this allows you to tweak the generated label file by hand.
ie the name you passed to v.label's label= option.
Hamish
