[GRASS-user] Uploading bounding box of vectors to database?
Martin Landa landa.martin at gmail.com
Tue Jan 5 17:14:46 EST 2010
2010/1/5 Christian Kaiser <Christian.Kaiser at unil.ch>:
> Thank you for your answer. It seems to me that v.info -g prints out the
> region for all the map. What I would need is the bounding box of EACH
> geometry (area for instance) in the map, and not the map as a whole.
> Probably my question was not clear... ;-)
v.db.select -r
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
