[GRASS-user] v.out.ogr kml error
Leonidas Liakos leonidas_liakos at yahoo.gr
Thu Jan 7 03:23:57 EST 2010
Try to export your data to shapefile and then use ogr2ogr to convert the shp to kml.
--- Στις Πέμ., 07/01/10, ο/η henry83 <heamaya at gmail.com> έγραψε:
Από: henry83 <heamaya at gmail.com>
Θέμα: [GRASS-user] v.out.ogr kml error
Προς: grass-user at lists.osgeo.org
Ημερομηνία: Πέμπτη, 7 Ιανουάριος 2010, 2:06
Hi everyone! I have created a contour map from a SRTM elevation model, after
filling nulls, filling depressions and creating the contour map I need to
export it to kml.
I have used the following command
v.out.ogr input=srtm_contours dsn=/home/henry/srtm_contours.kml format=KML
output:
WARNING: Vector map <srtm_contours> is 3D. Use format specific
         layer creation options (parameter 'lco') to export in 3D rather
         than 2D (default)
Exporting 360384 points/lines...
 100%
360384 features written
The thing is that if I try to open the generated file with google earth it
gets hanged...
Arterwards I tried to add this to the command:
dsco="AltitudeMode=absolute"
Neither I've gotten a good result. Does this problem have to be with "lco"
parameter? Because I really don't know what to put in that parameter, and I
really need to get the contours over google earth.
Any help will be appreciated. Thanks in advance.
View this message in context: http://n2.nabble.com/v-out-ogr-kml-error-tp4264064p4264064.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
___________________________________________________________
Χρησιμοποιείτε Yahoo!;
Βαρεθήκατε τα ενοχλητικά μηνύματα (spam); Το Yahoo! Mail
διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών
μηνυμάτων http://login.yahoo.com/config/mail?.intl=gr
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100107/fb4541a3/attachment.html
