[GRASS-user] Searching Docs about 3D geological modelisation
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Fri Jan 8 05:04:12 EST 2010
Rich Shepard wrote:
>> material. There is no interpolation algorithm in GRASS currently which
>> can
>> handle that sort of data well.
>   So what is needed is a political algorithm. :-)
That's actually right: given the presence of n different
layer types in the vicinity of an empty voxel, the algorithm
would need to decide by some sort of "majority vote"
which type to assign to that voxel.
>   Kidding aside, I suspect that a fuzzy interpolation algorithm would solve
> the problem.
How? You could make the interpolated value depend on a
fuzzy set member function, I suppose, but the situation
here is actually so well defined that I think a probabilistic
approach would be preferable. Since each voxel can only
store one value, a second output map could store the
classification probability. That may be very useful
for visualization (you could show voxels with little
probability hazier).
Ben
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
Geospatial Consultant
Oxford Archaeology Digital
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke at oadigital.net
http://oadigital.net
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
