[GRASS-user] SQL query
Hamish hamish_b at yahoo.com
Fri Jan 8 12:20:31 EST 2010
I have a bunch of maps in the same mapset with identical table structure
and with similar sounding names. With v.to.db I've uploaded a distance to
each of their 'length' columns.
The DB is SQLite and everything is stored in $MAPSET/sqlite.db.
Now I want to print them all out in a single command.
I tried this, but it doesn't work:
G65> db.select sql="SELECT length FROM table_name LIKE 'track_%'"
DBMI-SQLite driver error:
Error in sqlite3_prepare():SELECT length FROM table_name LIKE 'track_%'
near "'track_%'": syntax error
this works:
db.select sql="SELECT length FROM track_001 \
         UNION SELECT length FROM track_002 \
         UNION SELECT length FROM track_003"
but I have something like 100 maps and the statement would get too huge.
any hints?
thanks,
Hamish
