[GRASS-user] "active window" Definition
Fri Jan 8 17:38:06 EST 2010
Franz Schiller wrote:
> While I was reading G_window_rows definition at GRASS6 programmers manual, I
> found this definition:
> Number of rows in active window.
> What does active window means? Because I can read number of rows/columns
> from raster header. I'm not real sure of what is active window.
The "window" specifies the relationship between row/column indices and
cartographic or geographic coordinates.
All raster processing is performed on the grid specified by the
window; all input maps are automatically resampled to it.
Unless the program explicitly sets a window, it will be initialised
based upon either:
1. The contents of the GRASS_REGION environment variable.
2. The contents of the named region specified by the WIND_OVERRIDE
3. The contents of the WIND file in the current mapset.
The most common case is #3.
Programs which explicitly set a window include r.resamp.interp,
r.resamp.stats and r.resamp.rst. These all set the window to match the
input map, so that they read the "raw" data without any resampling.
