[GRASS-user] Re: Patch raster maps very slow - Is there a way to speed this up?
Hermann Peifer peifer at gmx.eu
Mon Jan 11 12:34:58 EST 2010
I would try to warp & patch the data with GDAL command line tools (gdalwarp in this case), then import the result into GRASS.
See also  http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp#WillincreasingRAMincreasethespeedofgdalwarp
Hermann
-------- Original Message  --------
Subject: Patch raster maps very slow - Is there a way to speed   this up?
To:
Date: 11/01/2010 14:20
> I have generated DEM tiles (65ish) from LIDAR data in its natural
> projection NC state plane feet (the area covered is about 300 squared
> miles).  I have reprojected them into UTM 17 nad 83.  These DEMs are
> 1m resolution.  I am using r.patch and it has been running for three
> days now and it is 45% done...  Would it be faster to stop this
> process, patch them in there native projection and then reproject them
> to UTM?  I am running GRASS 6.5.
> kind regards,
