[GRASS-user] Wxpython GUI in UBUNTU 9.10
Kim Besson kimbesson1981 at gmail.com
Wed Jan 20 12:09:23 EST 2010
Hello
Ok my bad. I didn't have python-wxgtk2.8 installed.
ok Now it's working but I got another ERROR and I guess this one has nothing
to do with WXpython.
An error windows stating
*ERROR in command execution g.region*
Unable to get current geographic extent. Force quiting wxGUI. Please run
manually g.region to fix the problem.
When I press ok the window and GUI closes and it get back to TERMINAL.
Any tips of what is happening?
Kim
2010/1/19 Hamish <hamish_b at yahoo.com>
> > Kim Besson wrote:
> > > I'm a new user of GRASS and I have downloaded grass (6.4.0~rc5-2) for
> > i386 architecture from http://packages.ubuntu.com/karmic/grass.
> > > as far as I can see GRASS by command line is working.
> > > Now the problem seems to be wxpython
> Micha wrote:
> > Check if you have installed the package python-wxversion:
> > micha at RMS:~$ dpkg -l | grep wxversion
> > ii  python-wxversion    2.8.10.1-0ubuntu1
> The 6.4 GRASS package there only Suggests python-wxgtk2.8 (which
> depends on python-wxversion), it isn't a mandatory requirement (tcl is).
> Maybe we should bump that up to "recommends".
> you might have a look at the other optional packages at
> and decide if you want to install them too.
> (sure, it could fail in a cleaner way too!)
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100120/a1d7c9e6/attachment.html
