[GRASS-user] r.patch: GRASS-6.5svn
Rich Shepard rshepard at appl-ecosys.com
Sun Jan 24 13:33:41 EST 2010
On Sun, 24 Jan 2010, Glynn Clements wrote:
> One possibility is that GRASS was initially built without LFS, then
> configure was re-run with --enable-largefile and GRASS was built without
> first performing "make clean". This would result in most of the files not
> be re-compiled.
Glynn,
   This must have been the case. I ran "make dist-clean", then "configure &
make & make install". When I ran r.patch on the 9 DEM maps it successfully
produced a 4.6G DEM file of the entire state.
   Normally, when I rebuild from source I run "make clean" or "make
dist-clean" first. Why I did not do so this time I don't know. Brain fart,
perhaps.
Thanks for guiding me to the proper solution,
Rich
