[GRASS-user] Re: [GRASS-dev] Compiling r.example in LINUX
António Rocha antonio.rocha at deimos.com.pt
Tue Jan 26 04:40:23 EST 2010
Greetings Glynn
The thing is that I went here:
http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster and I
donwloaded the r.example that is there.
At least I didn«t saw any information regarding GRASS version :(.
Now I realize thatr the trunk relates with 7.0 version and in Branches I
can find 6.4 version. :)
Ok After I did this:
sudo make -C Desktop/GRASS_dvp/r.example/
MODULE_TOPDIR=/usr/local/grass-6.4.0svn
Instead of putting r.example in /usr/local/grass-6.4.0svn my r.example
was putted in
/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu
this is the path to my snapshot from which I installed grass-6.4.0svn.
Shouldn't it be placed in usr/local/grass-6.4.0svn? Because altough it
has been compiled it's not available to be used.
Thanks for your help.
Antonio
By the way, the error text might be helpful:
ake: Entering directory `/home/anrr/Desktop/GRASS_dvp/r.example'
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc
-I/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/include
-g -O2       -DPACKAGE=\""grassmods"\"
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
gcc
-L/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/lib
-o
/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/bin/r.example
OBJ.i686-pc-linux-gnu/main.o  -lgrass_gis -lgrass_datetime -lz     -lm  -lz
make htmlcmd
make[1]: Entering directory `/home/anrr/Desktop/GRASS_dvp/r.example'
make
/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/docs/html/r.example.html
HTMLSRC=/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/bin/r.example
make[2]: Entering directory `/home/anrr/Desktop/GRASS_dvp/r.example'
if [
"/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/bin/r.example"
!= "" ] ; then
GISRC=/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/demolocation/.grassrc64
GISBASE=/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu
PATH="/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/bin:/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.example.tmp.html ; true ; fi
ERROR: MAPSET PERMANENT - permission denied
/usr/local/grass-6.4.0svn/tools/mkhtml.sh r.example ; mkdir -p
; /usr/bin/install -c  -m 644 r.example.tmp.html
; for file in  *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null
; if [ $? -ne 0 ] ; then /usr/bin/install -c  -m 644 $file
; fi done 2> /dev/null ; true
make[2]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/r.example'
make[1]: Leaving directory `/home/anrr/Desktop/GRASS_dvp/r.example'
make mancmd
make
/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/man/man1/r.example.1
MANSRC=/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu/docs/html/r.example.html
mkdir -p
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
/home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/tools/g.html2man/g.html2man
1
Converting:
to
make: Leaving directory `/home/anrr/Desktop/GRASS_dvp/r.example'
Glynn Clements wrote:
> António Rocha wrote:
>> I'm having a few difficulties in compiling modules (e.g. r.example).
>> *make -C r.example MODULE_TOPDIR=/usr/local/grass-6.4.0svn/*
>> /home/anrr/Desktop/GRASS_dvp/r.example/main.c:108: undefined reference to `Rast_map_type'
> You're trying to compile an example written for 7.0 against 6.4.
> A lot has changed between 7.0 and 6.x. E.g. all of the raster-specific
> functions have been removed from lib/gis and moved to lib/raster, and
> renamed from G_* to Rast_*.
> The r.example source code is included in the GRASS source tree, in
> doc/raster/r.example. The version in the 6.4 source tree should
> compile against 6.4.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4805 (20100125) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
