[GRASS-user] r.slope.aspect: Unexpected Results
Tue Jan 26 17:51:27 EST 2010
Rich Shepard wrote:
>    The source originally-imported DEM produces appropriate slope and aspect
> maps. The sub-region I cut out with v.in.region (I believe that's the module
> I used) doesn't calculate properly. Therefore, the problem is with the
> sub-map.
It's possible that the cropping may have changed the grid slightly.
What are the grid parameters (bounds, resolution, rows/cols) for the
source map and the cropped version?
You could try repeating the cropping process, using g.region's align=
option to align the grid to the source map.
