[GRASS-user] Problems Running r.flow
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Wed Jan 27 19:52:18 EST 2010
Hi Rich,
try g.region nsres=5 ewres=5, may be you can bypass this.
best regards
milton
2010/1/27 Rich Shepard <rshepard at appl-ecosys.com>
>  In -6.4svn from last Friday's weekly snapshot.
>  After setting "g.region rast=aber5m" I tried running "r.flow elevin=aber5m
> aspin=aber5aspect flout=aberFlowline lgout=aberFlowlength" and ran into
> resolution problems:
> Reading input files: elevation
> ERROR: Elevation file's resolution differs from current region resolution
>  g.region -p reports:
> nsres:      4.99982001
> ewres:      4.99979979
>  g.region rast=aber5m -p reports:
> nsres:      4.99982001
> ewres:      4.99979979
>  I also get the same error message about the aspect map (derived from the
> elevation map) which has the same resolution as above.
>  Any ideas what's going on? More importantly, how do I get his module
> running here?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100127/0d36e5da/attachment.html
