[GRASS-user] Problems Running r.flow
Rich Shepard rshepard at appl-ecosys.com
Wed Jan 27 23:02:08 EST 2010
On Wed, 27 Jan 2010, Milton Cezar Ribeiro wrote:
> But g.region res=5 and g.region nsres=5 ewres=5 produce the same result? I
> never tryed.
Milton,
   Yes. res is equal to setting both nsres and weres to the same values.
> Rich, another way is you use n= s= w= e= options, that may be will result
> something like -a, I suppose.
   That changes the bounds. I don't want to do that other than the small
increment necessary to get an integer resolution value.
Rich
