[GRASS-user] r.stream.basins
stephen sefick sas0025 at auburn.edu
Thu Jan 28 19:46:07 EST 2010
Thanks for the response - I moved the values to the closest synthetic
stream, and it worked without a hitch.  Thank you again for your time.
kindest regards,
Stephen
On Thu, Jan 28, 2010 at 6:37 PM, MS <mseibel at gmail.com> wrote:
> The points need to coincide with a nearby high value accumulation cell.
> Mark
> On Jan 28, 2010, at 4:22 PM, stephen sefick <sas0025 at auburn.edu> wrote:
>> I am having problems with r.stream basins.  I am trying to delineate
>> watersheds above GPSed points.  About half of the watersheds are being
>> delineated satisfactorily.  The others are very small sub watersheds
>> that are not the correct contributing areas.  I imagine that this is
>> because the point is not exactly on the stream?  I am using
>> r.watershed to produce the direction map and using a vector layer with
>> points GPSed in the field.  Any thoughts would be appreciated.
>> kind regards,
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>                               -K. Mullis
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Stephen Sefick
								-K. Mullis
