[GRASS-user] Using pipes in python scripts
Fri Jul 2 03:59:39 EDT 2010
Ned Horning wrote:
> I'm making progress translating my shell script to Python but ran into
> another stumbling block. I would like to convert the following shell
> script command to the python scrip:
> v.out.ascii $randomName fs=' ' | r.what  input=$resampName> $pointTableName
> I tried various combinations of grass.pipe_command and
> grass.feed_command but haven't been able to get it to work.
Using pipe_command() and feed_command() will give you two pipes (one
each), but you only want one. Use start_command():
	outf = file(pointTableName, 'w')
	p1 = grass.pipe_command('v.out.ascii',
		input = randomName,
		fs = ' ')
	p2 = grass.start_command('r.what',
		input = resampName,
		stdin = p1.stdout,
		stdout = outf)
	outf.close()
	p1.stdout.close()
	p1.wait()
	p2.wait()
start_command() is the most general function; all of the others
(except exec_command()) end up invoking start_command().
