[GRASS-user] Define Global Variables and use them in a Python
script
Kim Besson
kimbesson1981 at gmail.com
Tue Jul 6 04:26:54 EDT 2010
Hello Glynn
As soon as I arrive to the office I will give it a try. Thought that I could
have global variables such as LC_LANGUAGES and other GRASS_GLOBAL VARIABLES.
Is it possible to define them in Init.sh (or .bat) and be used in Python
Scripts?
Best regards,
Kim
2010/7/5 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > I've been testing and "kind of " using GRASS-Python scripts for nearly 2
> > weeks and it's being great. So far no major issues but now I need to do
> > something:
> > - From a text file (ASCII) I need to read a few variables and make them
> > global bariables I mean, be available and defined for a huge set of
> Scripts
> > in order to avoid to define those variables in each Script. And, in case
> I
> > change them, I only have to change in that ASCII File. My questions are:
> > 1- How can I do GRASS to read an external File in order to define GLOBAL
> > VARIABLES?
> > 2- How can I call them from a GRASS_SCRIPT?
> A "global" variable in Python is local to the module in which it's
> defined. So you you have a module named config, to access any global
> variables in that module from other modules you would need either
> "import config" (in which case, variables will be accessible as
> config.whatever) or "from config import *" (but as the program grows,
> the chances of name collisions increase).
> For a set of related variables, e.g. configuration parameters, it's
> usually better to make them all members of a specific object, e.g.:
> class Params(object):
> def __init__(self, filename):
> # initialise members from file
> # read the config file
> params = Params("config.cfg")
> Then you only need to import a single name:
> from config import params
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100706/ae917644/attachment.html
