[GRASS-user] Re: Wingrass 6.4 with MSYS does not work
Daniel Victoria daniel.victoria at gmail.com
Tue Jul 6 11:05:34 EDT 2010
I have no idea how mingw got into the path. Can't find it in my system
environment variables. removing it from the path will not change the
GNU Bash (Cygwin) line but now I don't see that bunch of python erros
on screen. All it does is, after I select the location, it will start
grass, tell me that wxvdigit does not work in windows and then gives
me a Goodbye from Grass. The next line shows:
$ Quit wxGUI. Grass is not running.
Could other python installs be messing this up (python 2.4 from ArcGIS)?
Thanks
Daniel
On Tue, Jul 6, 2010 at 10:47 AM, Luigi Ponti <lponti at inbox.com> wrote:
> Dear Daniel,
> On 06/07/2010 14:03, Daniel Victoria wrote:
>> Another thing I just noticed looking at grass64svn script
>> ArcGIS has set the variable PYTHONPATH=C:\Program Files (x86)\ArcGIS\bin
> I don't know, but there seem to be no "PYTHONPATH" string in the my GRASS
> installation folder.
>> Could that be related?
>> On Tue, Jul 6, 2010 at 8:54 AM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>>> Hi all,
>>> I don't see any leftover cygwin instalation in my path. I even tried
>>> removing python(xy) to see if that was the culprit.
>>> Here are some of the environmental variables set in the msys shell
>>> that I believe influences grass:
>>> PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/Windows/system32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/c/Program
>>> Files (x86)/OpenSSH/bin:/c/Windows/System32
> There is a mingw thing that may be where bash.exe comes from. Why do you
> need mingw in GRASS MSys? Wingrass has its own copy of MSys, and should not
> need to point to /mingw/bin or anything else related to unix shell.
> Kind regards,
> Luigi
