[GRASS-user] Error while using r.in.gdal for USGS landsat7 images
António Rocha antonio.rocha at deimos.com.pt
Thu Jul 8 07:47:28 EDT 2010
r.info displays normal information such as Extent, resolution etc... So
it seems all ok
Hamish wrote:
> António wrote:
>> I'm using r.in.gdal to import Landsat7 images downloaded
>> from USGS website. These landsat images are distributed in
>> UTM-WGS84 for the specific zone. in this case I'm working
>> with images from Brazil (WGS84 UTM ZONE 24S). So first I
>> created  an Location based on EPSG:32724.
>> Here goes the gdalinfo command for the image:
>> /Driver: GTiff/GeoTIFF
>> Files: L5216065_06520070405_B10.TIF
>> Size is 8171, 6991
>> Coordinate System is:
>> PROJCS["WGS 84 / UTM zone 24N",
>>    GEOGCS["WGS 84",
>>        DATUM["WGS_1984",
>>            SPHEROID["WGS
>> 84",6378137,298.257223563,
>>    AUTHORITY["EPSG","7030"]],
>>    AUTHORITY["EPSG","6326"]],
>>        PRIMEM["Greenwich",0],
>>    UNIT["degree",0.0174532925199433],
>>        AUTHORITY["EPSG","4326"]],
>>    PROJECTION["Transverse_Mercator"],
>>    PARAMETER["latitude_of_origin",0],
>>    PARAMETER["central_meridian",-39],
>>    PARAMETER["scale_factor",0.9996],
>>    PARAMETER["false_easting",500000],
>>    PARAMETER["false_northing",0],
>>    UNIT["metre",1,
>>        AUTHORITY["EPSG","9001"]],
>>    AUTHORITY["EPSG","32624"]]
>> Origin = (443999.999999999941792,-694500.000000000000000)
>> Pixel Size = (30.000000000000000,-30.000000000000000)/
>> As can be seen it's North instead of South. Nevertheless,
>> r.in.gdal imports it and it even says: Projection of input
>> dataset and current location appear to match
>> But when I try to display I get an error window stating:
>> Execution failed: 'd.rast -o map=import at PERMANENT --q'
>> Details:
>> Error: Unable to open raster map <import at PERMANENT>
>> And nothing else is stated
> what does "g.list rast" say? how about r.info?
> Hamish
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5261 (20100708) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
http://www.eset.com
