[GRASS-user] Re: r.fillnulls --- no result
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Thu Jul 8 07:45:51 EDT 2010
maven apache wrote:
>>>> Raster map <r_fillnulls_2468_filled> not found
>>>> <r_fillnulls_2468_filled> nothing removed
>>>> Removing vector <vecttmp_fillnulls_2468>
>>>> (Wed Jan 13 21:40:23 2010) Command finished (3 sec)
>>>> I wonder why?
>>>> I have uploaded the tif.
>>> Nobody ? :(
>> Did you use
>> g.region  rast=aaa at PERMANENT
> Yes, I use this commond before the r.fillnull.
Any added info about how r.fillnulls issue was solved.
We are getting the following error while using the latest
Cygwin-GRASS
r.fillnulls input=kagoshima_new at user1 output=kagoshima_fillnull
tension=40. smooth=0.1
Locating and isolating NULL areas...
Reading input raster map <r_fillnulls_2268 at user1>...
Writing output raster map <r_fillnulls_2268.buf>...
Finding buffer zones...
Creating interpolation points...
Extracting points...
Building topology for vector map <vecttmp_fillnulls_2268>...
Registering primitives...
1599 primitives registered
1599 vertices registered
Building areas...
r.to.vect complete.
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 1599
Number of primitives: 1599
Number of points: 1599
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
Interpolating 1599 points
Note: The following warnings may be ignored.
Removing raster <MASK>
Using segmentation for interpolation...
/usr/local/grass-6.4.0RC6/bin/v.surf.rst.exe: error while loading shared
libraries: ?: cannot open shared object file: No such file or directory
Note: Above warnings may be ignored.
Patching fill data into NULL areas...
/usr/local/grass-6.4.0RC6/scripts/r.fillnulls: line 237:
/usr/local/grass-6.4.0RC6/bin/r.patch: Permission denied
Removing raster <r_fillnulls_2268>
Removing raster <r_fillnulls_2268_filled>
Raster map <r_fillnulls_2268_filled> not found
<r_fillnulls_2268_filled> nothing removed
Removing raster <r_fillnulls_2268.buf>
Removing vector <vecttmp_fillnulls_2268>
       2 [main] g.remove 1796 exception::handle: Exception:
STATUS_ACCESS_VIOLATION
    1134 [main] g.remove 1796 open_stackdumpfile: Dumping stack trace to
g.remove.exe.stackdump
       2 [main] g.remove 1248 exception::handle: Exception:
     596 [main] g.remove 1248 open_stackdumpfile: Dumping stack trace to
Filled raster map is: kagoshima_fillnull
Raster map <kagoshima_fillnull> not found in current mapset
Done.
