[GRASS-user] convert to utm projection
Daniel Victoria daniel.victoria at gmail.com
Fri Jul 9 08:48:25 EDT 2010
I was not aware of the -p and -g flags
Nicer and nicer every time....
On Thu, Jul 8, 2010 at 9:43 PM, Hamish <hamish_b at yahoo.com> wrote:
> Daniel wrote:
>> Complementing Varun response, take a look at the r.proj manual page
>>  http://grass.ibiblio.org/grass65/manuals/html65_user/r.proj.html
>> Specially the Notes part, were it explains about the v.in.region trick
>> in order to set the region extent and resolution correctly
> fyi in grass 6.5 and newer there is also the r.proj -p and -g flags which
> make the v.in.region trick not really needed any more.
> Hamish
