[GRASS-user] Arc Binary coverages- arggg!
Mark Seibel
mseibel at gmail.com
Tue Jul 13 09:10:01 EDT 2010
Much to my delight, v.in.ogr reads the binary arc coverages. I copied
over the directory (which is the coverage name) and the info directory
to a place on the Linux machine which has GRASS installed. (not sure
if the 'info' directory is needed, but it did preserve attributes).
For the OGR datasource name, I pointed it to the "arc.adf" file, and
it imported the coverage as a GRASS vector with points, lines and
polygon features. Attributes also preserved.
Please let me know if you have any issues with this. First time I
tried this, and great to know it can read the binary coverages.
Mark
On Mon, Jul 12, 2010 at 8:02 PM, Mark Seibel <mseibel at gmail.com> wrote:
> That's what I figured. Then I am fairly sure this is what you're
> after, http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html.
> Arc Vector coverages are stored in 2 directories. One for geometry
> (the directory is the name of the coverage) and the database is
> contained in an 'info' directory. The examples below are not clear to
> me how it addresses this, but it does state it will do it. I could
> try some testing tomorrow if not figured out by then.
> # Arc Coverage
> We import the Arcs and Label points, the module takes care to build areas:
> v.in.ogr dsn=gemeinden layer=LAB,ARC type=centroid,boundary output=mymap
> # E00 file (see also v.in.e00)
> First we have to convert the E00 file to an Arc Coverage with
> 'avcimport' (AVCE00 tools, use e00conv first in case that avcimport
> fails):
> avcimport e00file coverage
> v.in.ogr dsn=coverage layer=LAB,ARC type=centroid,boundary output=mymap
> All the best.
> Mark
> On Mon, Jul 12, 2010 at 7:47 PM, stephen sefick <ssefick at gmail.com> wrote:
>> Vector Coverages.
>> On Mon, Jul 12, 2010 at 6:41 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>> Are these vector coverages or raster datasets?
>>> Mark
>>> On Jul 12, 2010, at 6:08 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>> I have a couple of files that are in this format...
>>>> aat.adf arx.adf dbltic.adf metadata.xml prj.adf txx.adf
>>>> arc.adf dblbnd.adf log par.adf txt.adf
>>>> they are arc binary data correct. Is there anyway I can use these
>>>> with GRASS or QGIS?
>>>> Stephen Sefick
>>>> ____________________________________
>>>> | Auburn University |
>>>> | Department of Biological Sciences |
>>>> | 331 Funchess Hall |
>>>> | Auburn, Alabama |
>>>> | 36849 |
>>>> |___________________________________|
>>>> | sas0025 at auburn.edu |
>>>> | http://www.auburn.edu/~sas0025 |
>>>> Let's not spend our time and resources thinking about things that are
>>>> so little or so large that all they really do for us is puff us up and
>>>> make us feel like gods. We are mammals, and have not exhausted the
>>>> annoying little problems of being mammals.
>>>> -K. Mullis
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Stephen Sefick
>> | Auburn University |
>> | 331 Funchess Hall |
>> | Auburn, Alabama |
>> | 36849 |
>> -K. Mullis
