[GRASS-user] Re: r.out.gdal output size vs input size
Espen Isaksen espen.isaksen at gmail.com
Wed Jul 14 05:41:02 EDT 2010
Quite possible that I did something wrong with the region :-)
I just used the default when creating the new location. And that is
probably 1 meter( I am dealing with 10 meter DEM's).
Can I somehow change the region resolution once the location is
created? Or force r.out.gdal to export with a different resolution
setting?
I can always create a new location, I am just curios to see if I can
fix this is my current location.
Espen
2010/7/14 LeeDaniel <Lee.Daniel.1986 at gmail.com>:
> Hi Espen,
> r.out.gdal uses the current region settings. Is it possible that you've set
> a high region resolution? Then your GeoTIFF is probably being resampled to a
> higher resolution, causing the file to be a lot bigger.
> Best,
> Daniel
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-out-gdal-output-size-vs-input-size-tp5291740p5291763.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
