[GRASS-user] Arc Binary coverages- arggg!
stephen sefick
ssefick at gmail.com
Wed Jul 14 10:01:59 EDT 2010
They were sent to me by some folk I am working with. I don't know how
they generated the coverages.
On Wed, Jul 14, 2010 at 8:59 AM, Mark Seibel <mseibel at gmail.com> wrote:
> How did you obtain the coverage? They are typically distributed as
> e00 files, which when imported create a directory for the geometry and
> an info directory for the attributes.
> Mark
> On Wed, Jul 14, 2010 at 9:20 AM, stephen sefick <ssefick at gmail.com> wrote:
>> I don't have an info directory. I tried using v.in.ogr to no avail.
>> So, I downloaded the nation hydrography dataset and now I am trying to
>> find out projection information.
>> thanks,
>> STephen
>> On Tue, Jul 13, 2010 at 8:10 AM, Mark Seibel <mseibel at gmail.com> wrote:
>>> Much to my delight, v.in.ogr reads the binary arc coverages. I copied
>>> over the directory (which is the coverage name) and the info directory
>>> to a place on the Linux machine which has GRASS installed. (not sure
>>> if the 'info' directory is needed, but it did preserve attributes).
>>> For the OGR datasource name, I pointed it to the "arc.adf" file, and
>>> it imported the coverage as a GRASS vector with points, lines and
>>> polygon features. Attributes also preserved.
>>> Please let me know if you have any issues with this. First time I
>>> tried this, and great to know it can read the binary coverages.
>>> Mark
>>> On Mon, Jul 12, 2010 at 8:02 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>>> That's what I figured. Then I am fairly sure this is what you're
>>>> after, http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html.
>>>> Arc Vector coverages are stored in 2 directories. One for geometry
>>>> (the directory is the name of the coverage) and the database is
>>>> contained in an 'info' directory. The examples below are not clear to
>>>> me how it addresses this, but it does state it will do it. I could
>>>> try some testing tomorrow if not figured out by then.
>>>> # Arc Coverage
>>>> We import the Arcs and Label points, the module takes care to build areas:
>>>> v.in.ogr dsn=gemeinden layer=LAB,ARC type=centroid,boundary output=mymap
>>>> # E00 file (see also v.in.e00)
>>>> First we have to convert the E00 file to an Arc Coverage with
>>>> 'avcimport' (AVCE00 tools, use e00conv first in case that avcimport
>>>> fails):
>>>> avcimport e00file coverage
>>>> v.in.ogr dsn=coverage layer=LAB,ARC type=centroid,boundary output=mymap
>>>> All the best.
>>>> Mark
>>>> On Mon, Jul 12, 2010 at 7:47 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>>> Vector Coverages.
>>>>> On Mon, Jul 12, 2010 at 6:41 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>>>>> Are these vector coverages or raster datasets?
>>>>>> Mark
>>>>>> On Jul 12, 2010, at 6:08 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>>>>> I have a couple of files that are in this format...
>>>>>>> aat.adf arx.adf dbltic.adf metadata.xml prj.adf txx.adf
>>>>>>> arc.adf dblbnd.adf log par.adf txt.adf
>>>>>>> they are arc binary data correct. Is there anyway I can use these
>>>>>>> with GRASS or QGIS?
>>>>>>> Stephen Sefick
>>>>>>> ____________________________________
>>>>>>> | Auburn University |
>>>>>>> | Department of Biological Sciences |
>>>>>>> | 331 Funchess Hall |
>>>>>>> | Auburn, Alabama |
>>>>>>> | 36849 |
>>>>>>> |___________________________________|
>>>>>>> | sas0025 at auburn.edu |
>>>>>>> | http://www.auburn.edu/~sas0025 |
>>>>>>> Let's not spend our time and resources thinking about things that are
>>>>>>> so little or so large that all they really do for us is puff us up and
>>>>>>> make us feel like gods. We are mammals, and have not exhausted the
>>>>>>> annoying little problems of being mammals.
>>>>>>> -K. Mullis
>>>>>>> _______________________________________________
>>>>>>> grass-user mailing list
>>>>>>> grass-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> Stephen Sefick
>>>>> | Auburn University |
>>>>> | 331 Funchess Hall |
>>>>> | Auburn, Alabama |
>>>>> | 36849 |
>>>>> -K. Mullis
>> Stephen Sefick
>> | Auburn University |
>> | 331 Funchess Hall |
>> | Auburn, Alabama |
>> | 36849 |
>> -K. Mullis
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
