[GRASS-user] DBMI-DBF driver error
Sandile Gumede akasandile at gmail.com
Thu Jul 15 07:10:50 EDT 2010
Hi
Can anyone help me on this problem?
On Wed, Jul 14, 2010 at 1:31 PM, Sandile Gumede <akasandile at gmail.com>wrote:
> Hi,
> I'm using GTOPO30 DEM data and TRMM (rainfall) data, I selected the data
> for the whole of africa but I'm getting an error when executing
> v.rast.stats.
> Here is a step-by-step of what I did:
> 1. GTOPO30 DEM
>        - downloaded e020n10,w020s10,e020n40,w020n40 compressed files from "
> ftp://edcftp.cr.usgs.gov/pub/data/gtopo30/global/".
>        - decompressed all the above files.
>        - Added "PIXELTYPE SIGNEDINT" in all .HDR files
>        - warp merged all the .DEM file with  "gdalwarp *.DEM Africa.tif"
> command.
>        - projected it with "gdal_translate -a_srs EPSG:4326  Africa.tif
> DEM.tif"
> 2. TRMM "rainfall" data
>       - downloaded 3B42RT.2010061503.1day.tif,3B42RT.2010061503.1day.tfw
> from "".
>       - projected it with "gdal_translate -a_srs EPSG:4326 -projwin -20 40
> 60 -60 3B42RT.2010061503.1day.tif TRMM.tif ".
> Then, imported the two data sets:
> r.in.gdal in=/home/tgumede1/grassdem/ict4eo/DEM.tif out=dem
> Projection of input dataset and current location appear to match
>  100%
> r.in.gdal complete. Raster map <dem> created.
> g.region rast=dem
> r.in.gdal in=/home/tgumede1/grassdem/ict4eo/CapeTown_TRMMs.tif out=rainfall
> target=CapeTown
>  100%
> r.in.gdal complete. Raster map <rainfall> created.
> r.watershed elevation=dem accumulation=acc drainage=direction stream=str
> basin=catch memory=300 threshold=100000
> SECTION 1a (of 5): Initiating Memory.
> SECTION 1b (of 5): Determining Offmap Flow.
>  100%
> SECTION 2: A * Search.
>  100%
> SECTION 3: Accumulating Surface Flow.
>  100%
> SECTION 4: Watershed determination.
>  100%
> SECTION 5: Closing Maps.
>  100%
>   Q: How do one really know the exact threshold value?
> r.to.vect in=catch out=catchments feature=area
> Extracting areas...
>  100%
>  100%
> Building topology for vector map <catchments>...
> Registering primitives...
> 134246 primitives registered
> 701002 vertices registered
> Building areas...
>  100%
> 44645 areas built
> 1 isles built
> Attaching islands...
>  100%
> Attaching centroids...
>  100%
> Number of nodes: 89602
> Number of primitives: 134246
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 89604
> Number of centroids: 44642
> Number of areas: 44645
> Number of isles: 1
> Number of areas without centroid: 3
> r.to.vect complete.
> g.region rast=rainfall
> v.rast.stats vector=catchments raster=rainfall colprefix=precip
> WARNING: Area without centroid (may be OK for island)
> DBMI-DBF driver error:
> SQL parser error: syntax error, unexpected NULL_VALUE processing 'NULL'
> in statement:
> UPDATE catchments SET precip_cf_=-NULL WHERE cat=17
> Error in db_execute_immediate()
> ERROR: Error while executing: 'UPDATE catchments SET precip_cf_=-NULL WHERE
>        cat=17'
> - output of r.info -g
> r.info -g rainfall
> north=40
> south=-60
> east=60
> west=-20
> - output of v.info
> v.info -g catchments
> north=40
> south=-60
> east=60
> west=-20
> top=0.000000
> bottom=0.000000
> output of r.info
> Type of Map:  raster               Number of Categories: 2559
>     Data Type:
> CELL
>     Rows:
> 400
>     Columns:
> 320
>     Total Cells:
> 128000
>          Projection:
> Latitude-Longitude
>              N:        40N    S:        60S   Res:
> 0:15
>              E:        60E    W:        20W   Res:
> 0:15
>     Range of data:    min = 0  max =
> 2559
>     Data
> Description:
>      generated by
> r.in.gdal
> Comments:
>      r.in.gdal input="/home/tgumede1/grassdem/ict4eo/CapeTown_TRMMs.tif"
>      output="rainfall" target="CapeTown"
> - output of r.univar
> r.univar rainfall
>  100%
> total null and non-null cells: 115200000
> total null cells: 0
> Of the non-null cells:
> n: 115200000
> minimum: 0
> maximum: 2559
> range: 2559
> mean: 22.4897
> mean of absolute values: 22.4897
> standard deviation: 83.1312
> variance: 6910.79
> variation coefficient: 369.642 %
> sum: 2590809300
> Kind Regards
> TS Gumede
> CSIR, Meraka Institute
> 072 258 1650
Kind Regards
TS Gumede
072 258 1650
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100715/5fd5399e/attachment.html
